Been a while since I've posted, because the car has been running well (jinx). But the overdrive refuses to engage, so we've just been doing without. With the cable pushed in, you get to the overdrive shift speed, let off the gas pedal, you can hear the relay and solenoid clack, but then the overdrive doesn't fully engage, and you get this horrible gear clash noise. The electrical system seems to be fine -- it passes the checklist, and as far as we can tell, the control cable is adjusted correctly, so that the control lever is fully engaged when the cable is pushed in. It's as if the solenoid armature doesn't have the full throw on it so that the control pawl doesn't engage. We've never removed the solenoid from the unit, and it used to function fine.
Anyone have any suggestion on this?
