In another recent thread (V8 overheating) I was asking for help with an overheating problem on my 51 Land Cruiser. I suspected the water pump was part of the problem because the pulley was about 1/4" forward of the crank pulley.
Yesterday, I decided to pull off the water pump to see if I could find why the pulley didn't line up with the crank pulley. I discovered that it was a rebuilt pump and the clearances were not correct according to information I have received from Bob Johnstone's website. The whole shaft including the pulley and the impeller was about 3/32" forward (toward fan) as has been a problem with some rebuilt pumps.
I don't have a hydraulic press so I thought I might try rapping the end of the shaft with a hammer to move it. I figured that if I broke something or damaged the seal I would have to buy a new water pump anyway. Well, somehow I managed to make the clearance situation worse so the impeller is now rubbing against the back of the shaft housing. I guess the impeller had more "body at rest" inertia than the shaft had "body in motion" inertia. So I need a new water pump for sure.
So now my question is this: which water pump should I order? My car was built in February 1951 and the engine number is V 27242 (51 V8 engine numbers started at V101). Is this what is referred to as an "early 51 V8"? I have seen some venders advertise water pumps for all models 51-64 V8 (part number 527070) and others also list early 51 V8 (part number 527242). The rebuilt pump that was on my car was part number 527070 so I know the pump for the later V8 actually fits into the water pump housing. Perhaps some of the misalignment of the pulleys might be due to a longer shaft on the leter engines?
thanks in advance for your help.
Jim
Jim
