Ordering some parts and the manuals for the 63 lark this week.I found a number of threads refering to the hub puller for the rear drums but no part number.I found several listed at SASCO but none say what they fit.Anyone know what part number I need?Thanks in advance,Steve
Which hub tool ?
I prefer the kind pictured. Studebaker did have a service tool for this (don't know the number). The Studebaker hub puller was a solid, circular piece that bolted to the drum and you drove a wedge into it to loosen the hub. When I had the option of either type, I used the aftermarket type pictured.
Studebaker enthusiast much longerGary L.
Just a warning on the type pictured above. We have a member injured when a part broke when being hit with the pictured hammer. With the abundance of cheap tools available today, I prefer to use a 3/4" drive socket set with a jack handle for leverage. With lots of tension on the tool, remove the socket and strike it with a hammer, if necessary(but not full strength), to shock the hub loose.
I've been whacking mine with that big hammer for 30 years, and it was old when I bought it. I've seen some older ones that the dog bone ears were mushrommed from daily use back in the days when a shop used them more, but never heard of breaking one, but would never consider buying a cheapie just in case.
JDP/Maryland
JDP Maryland
Mark Hayden
'66 Commander
Thanks for all the input.My boss at work has one he says I can use if he can find it.If not I have a couple marked in my E-bay account.I am going to have to buy one eventually anyway as I have the 53 to do also and am about to make an offer on three more larks,all with standard studebaker brakes(none).
I also need a pic if anyone has one of a valve spring tool that will work on the 53 flathead 6.I have a couple but none work well on it for various reasons(Too long,too thick,etc..).sigpic
