What is the 289's "sweet spot" as far as cruise RPM for the best highway fuel economy? I've finally settled on the 289 with a 200-4R swap and I need to select my rear end gears so I can order the speedo gears for the trans. I'm going to give my tranny guy the green light in a few days and the speedo drive gear is one of the first things that has to go in since the 200-4R does not have a removable tail housing for access.
My car was originally a 224 V-8 and currently has a 4.10 or 4.27 and that is too low even with the OD. 1st gear is almost useless with whatever gear isout back, let out the clutch drive 50 feet and it's time to begin the hopeless search for 2nd gear. [
)] A 3.42 or thereabouts behind the 200-4R would give me the same cruise RPM as my T-86 with a 3.31 and I know the 200-4R works VERY nicely with 3.42 gears behind a small cube engine. 1st gear launch would be the equivalent of the T-86 with a 3.64 rear end plus I would have the torque multiplication of the torque converter. I think a stock lockup converter from a 305 HO Monte SS would be just about right. The 3.42 would be much more usable behind the 289 I "think".
Analog man in a digital world.
