View Full Version : Aluminum Lark Radiator
mbstude
05-14-2008, 06:49 PM
The radiator puked out on me today, along with the water pump. I scrounged around the shop and found a Lark/Hawk radiator, made of aluminum. Looked completely stock, except for what it's made of. Got it in the Lark, and it seems to work fine.
Any ideas on what the heck it came out of? Never seen another one. [?]
Matthew Burnette
Hazlehurst, GA
http://i81.photobucket.com/albums/j209/mbstude/avatar-9.jpg
05-14-2008, 06:56 PM
It was probably a stock radiator, re-cored with an Aluminum core.
You will need to keep lot's of Anti-Freeze in there, at least 50% to keep the corrosion down. Maybe no dissimilar metal problem though, since it is isolated from the iron engine.
Studebakers Northwest
Ferndale, WA
mbstude
05-14-2008, 07:02 PM
It's got aluminum tanks. Aftermarket tanks maybe?
Matthew Burnette
Hazlehurst, GA
64V-K7
05-14-2008, 07:09 PM
Is is a cross flow or vertical flow? I bought an aluminum rad from Summit and it almost a drop in for my Hawk
Bob Johnstone
http://www.studebaker-info.org/7168422/sig2.jpg
55 President State Sedan
64 GT Hawk
70 Avanti (R3)
mbstude
05-14-2008, 07:12 PM
Vertical flow, I would guess. The 'rows' go vertically, if that's what you're referring to.
Matthew Burnette
Hazlehurst, GA
fstst56
05-14-2008, 07:34 PM
Bob,
Can you tell us a little more about this radiator you got from Summit? I'm needing to replace the radiator in my '56 Golden Hawk.
ST2DE5
05-14-2008, 09:33 PM
If it's aluminum and copper you will have a problem. Aluminum and copper are bitter enemys. Many a air conditioner has went bad where the 2 connect. Summit has a radiator that is real close to my 56 Parkview.
http://i220.photobucket.com/albums/dd185/51stude/OzarkTtrailLogoSmall.jpg
mbstude
05-15-2008, 07:22 AM
It's all aluminum. Upon a little closer inspection, it looks like another rad was used with the Lark side pieces. That would make sense. :)
Matthew Burnette
Hazlehurst, GA
ST2DE5
05-15-2008, 08:41 AM
Let us know how it works out. I must be old fasion but I have always been scared to try one.
