View Full Version : air conditioning pully
dallastx75208
10-21-2006, 09:07 PM
I have a 62 hawk with power steering which means I have two pullies. I am going to add air from vintage air, do I need to add a third pully?
Thanks, Jon
N8N
10-21-2006, 09:22 PM
Ayup. I don't know if Vintage Air sells the pulley or not, but you've got two options. You could track down a factory Stude crank pulley for A/C which is hard to find and probably not cheap. Alternately I have heard of people adding a second power steering pulley; the only difference is that the groove is a little narrower and therefore the wider A/C belt will ride a little high in it. You'll also need another aluminum spacer, but that is a standard part.
N8N
John Kirchhoff
10-21-2006, 10:49 PM
Mine has factory air and I don't know how close the dimensions for the compressor bracket will be to the OEM bracket, but if it's similar and you use a York compressor, you may have to get a double compressor pully and use the outside groove. If I had to replace my compressor or was unable to use the existing pully, that's what I would have to do. I know this because I must have a dozen different compressors, pulleys and clutches I've fiddled with out of curiosity.
John Kirchhoff
studeclunker
10-21-2006, 11:03 PM
My '63 Daytona Wagon has a triple pulley at the balancer (bottom) and a double pulley at the (WARDS) aftermarket compressor. It then runs the compressor, alternator, and an idler off those two belts. One belt is idler, balancer, compressor and the other is compressor, alternator, balancer, waterpump. I don't know if this is right. The car isn't currently running. Hasn't been for thirty years that I know of.
Lotsa Larks!
Ron Smith
studeclunker
Lotsa Larks!
Ron Smith
John Kirchhoff
10-21-2006, 11:10 PM
I always think of something as soon as I post the message. The stock setup also uses double pulleys on the waterpump/fan blade shaft. That will probably be even tougher to find than a crankshaft pulley. I can't be sure without actually looking, but wonder if there is adequate clearance for the belt to run directly off the crank to the compressor. I can't be sure right now. I know I put an extra pulley on my '51. I used another fan belt/generator pully and bored holes and bolted it to the existing one. That way I didn't have to go looking for double pullies and the longer crankshaft bolt. However, that pulley is narrow enough that the belt may slip excessively when under a heavy load. If so, chances are it won't be at high speeds but instead putting around town. Of that I'm speaking from experience. With the 9 cubic inch York compressor, it'll draw 3.5-4 horsepower. By comparison, it takes one horsepower for an alternator to produce approximately 23 amps. In other words, you'll easily be putting twice the horsepower through the belt, so a narrow belt or one that rides high on a narrow pulley could be problematic. If you can run the belt directly from the crank to the compressor, if at all possible try to put the idler pully on the bottom (a pain), the idle side of the belt rather than on the driving side. I had an aftermarket system on a truck like that and belt slippage and wear were excessive. The Seiki and Sanyo compressors take less horsepower but most don't have the capacity of the 9 ci York either. I've seen where some people mount one of those *** compressors where the generator/alternator sets and then mounts an alternator where the power steering pump usually sets.
John Kirchhoff
whacker
10-22-2006, 01:42 PM
I have seen a setup where the compressor was mounted in the "V", on the passenger side of the oil filler mast. The belt then ran around the crankshaft to the compressor, and over to the power steering pump. The power steering pump was used as the tensioner. I don't know how well it worked, but it sure looked slick. This setup used the Sanden, I think a 508, but I'm not sure. This place might help you out, I've found them quite helpful:
http://www.nostalgicairparts.com/getcategory.php?cat=7
whacker
10-22-2006, 03:41 PM
I thought J & N auto air had had some pulleys made up for Stude AC installations? Ebon? You lookin' in here?
Miscreant adrift in
the BerStuda Triangle!!
Miscreant adrift in
