I have removed my stock fan and I am adding two electric fans to my Lark. One larger, higher CFM fan as the puller and one smaller, lower CFM pusher fan.
My question is how should I mount them in relation to the Radiator? Does it really matter? I know the coolant is hottest when it enters the radiator, but the coolant enters the block from the bottom. Should I put the bigger fan in the bottom corner closest to the exit of the radiator back to the engine and put the smaller one at the top closest to the inlet of the radiator as the back up as needed?
Advice, whether good or bad, is always appreciated.
Kel
1961 Studebaker Lark VIII. 6x,xxx miles from the factory. Daily driven.
Kel
