Talked to the machine shop today and got some bad news.
The area that #2 cam bearing set in [don't know the term] is almost .002 over sized from the rest. Seems to have been that way from the factory. Every thing is clean and shows no wear. The bore marks are still there.
This was discovered when they went to line bore for the cam.
He was hoping to find a bearing that would fit, but no luck.
If I go ahead and put it back together like it was, the bearing may turn and block the oil passage. Big trouble![xx(]
Have any of you Stude engine builders run into this? What did you do?
I could get another block and start over. That would be paying for 2 rebuilds. NOT GOOD![8]
I know it worked that way for 130K miles. But my luck is not as good as J.D.P.'s. Help, please.
Thanks again.
John Ratliff
Thanks again.
John Ratliff
