Thanks much, 55prez and Alan for all your help. We borrowed a new Chuck Collins repro spreader tool from another SDC member and replaced the upper and lower outer pins on my '59 Lark VIII, actually they are going on the '59, but they are '61 Lark King Pin/A arm assembies that were already rebushed on the inner ends. I am aware that I will need to align it with close to 0 degrees instead of -2 1/2 caster with the late style king pins.
But here is the problem...the spreader holds the top of the A arms, but under what must be 250-300 ft.LBS of torque it takes to really force those outer pin caps to thread all the way flush with the A arms, the bottom pinches in .030 to .100 thou, when it should hold .015! The repair manual shows the spreader mounted on top of arm, so we mounted it there and spread it to 2.750 + .015 and wrenched away on those caps, a little at a time on each end. They are unbelivably hard to drive in. The result was that there may not be enough room to move the K/P to read 0 degrees to -1 1/4 to align it. I can see those grease seals being really flatened if it will even go that far. It would be way worse on a pre '61 where it requires up to -2 1/2 degrees caster! Has everyone who does this right had to fight this hard to do it? exhausted and dissapointed - Rich.
PS almost makes you want to put one O-those cheeseball pinto front ends in! [xx(]
quote:
Originally posted by Alan
2.750" or 2 3/4"
added by Rich
this is the correct spread of the outer end of the '51-'66 upper & lower "A" arms.)
Studebakers Northwest
Ferndale, WA
2.750" or 2 3/4"
added by Rich
Ferndale, WA
