Pulling Spedo Drive from t10
  • Pulling Spedo Drive from t10
    Anyone try to remove the spedomotor drive from the tailshaft of a t10. I attempted to do it according to the manual and all I do I break my puller. I can't get it into my hydraulic press. Any other suggestions?
    78 Avanti RQB 2792
    64 Avanti R1 R5408
    63 Avanti R1 R4551
    63 Avanti R1 R2281
    62 GT Hawk V15949
    56 GH 6032504
    56 GH 6032588
    55 Speedster 7160047
    55 Speedster 7165279
    I've done it before and I believe I warmed it up with a propane torch and kept a wet rag around the output shaft. I used the puller and had no problem. When I reinstalled it I put the output shaft in the freezer for awhile and again warmed/heated the speedo gear. It slid on by hand but you have very little time so make sure you know where you want it before you start.
      I just rebuilt two t-10's. I don't understand what you are having a problem with. First off don't heat the ring the clearence is slight not somthing you need to heat.Iam guessing you have the tail shaft
      housing off but the trans is not apart?Is the trans out of the car?
      Are you trying to use a puller like in the shop manual?Are you going to reuse the gear?
      1959 HARDTOP R2 clone
      1960 conv
      SDC member since 1972
      1959 HARDTOP R2 4speed
      1960 conv R2 auto
      http://i237.photobucket.com/albums/ff21/59r2/DSC01514-3.jpg
        59r2,
        I removed the transmission to rebuild it. It was growling a bit and I was working on the clutch anyway... I have the transmission mostly disasembled. The main shaft is out of the transmission. I have a puller very similar to the one in the book. So far, the gear just won't budge. I had planned on re-using the gear, however, if it is readily available, I don't mind buying a new one.
        78 Avanti RQB 2792
        64 Avanti R1 R5408
        63 Avanti R1 R4551
        63 Avanti R1 R2281
        62 GT Hawk V15949
        56 GH 6032504
        56 GH 6032588
          nels,
          Thanks for the suggestion. I don't know why it's stuck on there so hard. I haven't rebuilt one of these since I was a kid about 40 years ago, but I don't remember having this much trouble. I'm soaking it in PB Blaster now, we'll see if the morning brings any relief. If not ... the torch might help.
          78 Avanti RQB 2792
          64 Avanti R1 R5408
          63 Avanti R1 R4551
          63 Avanti R1 R2281
          62 GT Hawk V15949
          56 GH 6032504
          56 GH 6032588
