View Full Version : Cruiser no start - end of story
65cruiser
10-15-2006, 07:39 PM
I've been out of town for the weekend and decided to wash the Cruiser this afternoon. I started it and backed it out of the garage. It was a bit harder to start than usual, but sometimes when it sits for a few days that happens. Anyway, she did fire up and I backed her out of the garage.
Later, she wouldn't start at all. I could smell gas, so I figured she was flooded. I mashed the gas all the way to the floor and tried to get her started, but nothing. I let her sit for a few hours and tried again. She'd try to hit every once in a while, but wouldn't fire. I've not done much troubleshooting so far, but ideas are welcome.
It has gas. I have a nice steady stream coming out of the fuel line. I checked the points, and they looked good. I have spark at the spark plugs, but it does look a little weak. It has a little red spark instead of the blue I'm used to seeing--but then again I've never checked it on this car before (or maybe I didn't have the wire grounded good enough). I pulled a few of the plugs and they looked normal, not wet or fouled. I buttoned it all up and shot some ether down the carb and tried again. Still nothing (other than an occasional cough). I got tired of messing with her and came in the house.
Ideas? What should I check next? It was just running, so I know it's not something really bad.
________________________
Mark Anderson
1965 Cruiser
http://home.alltel.net/anderm
http://home.alltel.net/anderm/images/smstude.jpg
41 Frank
10-15-2006, 08:12 PM
One other thing you might check is if the fuel is actually getting into the carburator bowl. Just because you have a fuel supply at the line into the carb does not necessarily mean it is getting past the needle and seat and into the carb. Take the air cleaner off and see if you can see a squirt of gas in the carb.when pumping the foot feed.
John Kirchhoff
10-15-2006, 10:22 PM
I agree with Frank, I have a Dodge truck in which the float sticks, shutting off the flow of fuel sometimes after it has set for some time. Unscrew the gas line, poke a piece of wire in the hole and then it's set to go.
Did you get your car washed and did the plug wires get wet? I had a high mileage Tempo once that got to where it wouldn't start on foggy mornings but would start later in the day. Even though it was in a shed, there was enough humidity to allow the old plug wires to leak juice even though they looked fine. After putting on new ones that was the end of the problem no matter how foggy or wet it was.
studeclunker
10-16-2006, 03:58 AM
I agree with Frank in that just because you have a fuel supply, doesn't mean it is getting into the carb. In my case, it was a piece of rust about 1/16th of an inch long that had lodged in the intake. It prevented any gas from getting into the carb. Old gas tanks, what can I say...[:I]
Lotsa Larks!
Ron Smith
65cruiser
10-16-2006, 08:10 AM
I don't think it's going to be that easy. I've got a nice stream of gas in the carb throat when I work the throttle. Also, it won't start with starting fluid either.
Lotsa Larks!
Ron Smith
Mark Anderson
1965 Cruiser
John Kirchhoff
10-16-2006, 09:05 AM
You know what they say, a lot of carburation problems are solved by working on the electrical system. The stronger the spark, the better able it is to get an out of whack fuel mixture going. Old motorcycles used to have notoriously weak ignitions. Get the fuel/air mix off jsut a bit and they wouldn't run, spark plugs would last maybe 5,000 miles tops. They'd look fine but would miss on acceleration.
You mentioned a reddish looking spark. It should be bright blue and rather energetic, not just a puny little jump. Try dragging a piece of heavy paper like a business card through the points to remove any crud that may have accumulated. If the points have some funky looking white crud on them, it's time for a filing. One way to weed out components is to energize the system (turn the key on) and with the distributor cap off, open and close the points with your thumbnail. The engine will need to be rotated to where the points will close completely. Hold the end of the wire that did go into the top of the distributor cap a short didtance from the block and work the points with your thumb. You should get a spark and you can then see the quality of it. If the points are clean (use the card trick after filing) and you still have the puny spark, it's probably the coil. Check the coil terminal for corrosion before replacing it. I've had coil that leaked oil and that was a good sign they were on their way out, but not all bad coils exhibit that. If the spark looks good, check the terminals on the distributor cap inside and out for corrosion, plug wires and anything past the coil (such as the metal plug wire holders on the valve cover, etc). If you put a new/different coil on, be reminded most new coils have a different resistance value and if you can't get an old style one, you'll need to wire in a ballast resistor on the hot side. Chrysler used lots of them and they're cheap. Run one of those coils without one and in short order they've left the land of the living.
65cruiser
10-16-2006, 12:09 PM
Okay, so it's pointing to the coil. I checked again for gas at the carb. Nice healthy squirt when I work the throttle. I pulled a spark plug and clamped it to the engine. Weak spark if at all. I removed the distributor cap and it's nice and clean (nearly new). Checked the points with a business card. No gunk--in fact they look really good. So, I turned the key on, removed the coil wire from the distributor and worked the points while I held the coil wire near the block. SOMETIMES I'll get a spark, and when I do, it's weak.
I'm going to assume the coil went south. Sound logical? My local Flaps has the coil I need for $16.00. I think I'll try replacing that and see what happens.
Mark Anderson
1965 Cruiser
John Kirchhoff
10-16-2006, 04:27 PM
Sounds like it, you should easily get a 1/4 inch spark.
65cruiser
10-16-2006, 08:10 PM
The saga continues. Based on the earlier diagnosis, I felt like the coil was weak. I replaced the coil. I checked all the connections and filed and reset the points. Then, I checked to make sure I had a good strong spark at the coil--it did. I wondered why it would not start. I pulled a spark plug wire and checked for spark there. It had a good spark, in fact the car started running on 5 cylinders. I turned it off, reattached the spark plug wire and restarted the car. It ran very roughly for maybe 45 seconds or so, then seemed to run slower and slower and finally died. Now, when I try to restart it kinds stumble, stumble, stumble, then just cranking. It's like it's trying to start, but just can't quite fire. I again checked for fuel flow, and even removed the top from the carb to check the bowl to make sure it was full of gas and the float wasn't stuck. All looked okay there. Put it all back together and tried again. Still no start.
I've done the following:
Replaced rotor and button
Refiled and reset the points
Replaced the coil
Checked for fuel flow
Checked for good spark at coil (good)
Checked for spark at plugs (good)
Checked firing order (don't know why, but it seemed like a good idea)
I'm running out of things to try. I've run the battery so low it's on a charger now.
Help[}:)]!
Mark Anderson
1965 Cruiser
ROADRACELARK
10-16-2006, 08:55 PM
Mark,
Check the rotor in the distributor. Some of those older style rotors have a small piece of carbon that makes the connection between the outer tab (toward the plug wire terminal) and the center tab that contacts the coil wire terminal. That piece of carbon can become loose and will start to arch...no run[xx(]. Also check the coil wire terminal inside the dist. cap...sometimes they loosen also.;) Hope this helps.
Dan Miller
41 Frank
10-16-2006, 09:02 PM
If like you say you have a strong spark and plenty of fuel now, possibly the spark is not coming at the proper time. Could the timing adjustment have moved because of a possible loose distributor and it is now retarded a whole bunch.
65cruiser
10-16-2006, 09:31 PM
I replaced the rotor and distributor cap. Is that what you're talking about or something else?
quote:Originally posted by ROADRACELARK
Mark,
Dan Miller
Mark Anderson
1965 Cruiser
65cruiser
10-16-2006, 09:33 PM
I wondered that and haven't checked it--althought the dist is tight. One thing about this is something suddenly "happened". It wasn't something that came on gradually. Also, when it DID start tonight, other than running a bit rough, it was running. I would think if the timing were that far off, it wouldn't have started at all.
Mark Anderson
1965 Cruiser
55s
10-16-2006, 11:37 PM
The only failure I have ever had in a Stude was when the centrifugal weights came off the vacuum advance and jammed the distributor, breaking shear pin at bottom of distributor. See if the rotor spins with the engine.
Other: reseat/ perhaps replace the coil distributor wire.
re-arch rotor spring. Check for proper opening/closing of points.
Good Luck,
Paul
Rosstude
10-17-2006, 12:43 AM
Sounds like you got fuel, but the spark is questionable. I have had points that proved to be no good even after filing, running a card through, and all kinds of poking about. The problem was that they were not making contact reliably. Donít rule out the points, they are pretty cheap and easy to replace on a 6 (which I think you have).
I have had inexpensive plug wires give me fits too, but normally they run, just very poorly.
Have you checked the voltage to the coil? I think your car has a resistor wire, that or a ballast resistor, each have been known to fail. A jumper wire with some alligator clips can, with some thought, be used to trouble shoot the points, and voltage supply.
Ross.
Riverside, Ca.
1957 Provincial X2
1958 Transtar
1963 Lark. F.S.
65cruiser
10-17-2006, 12:09 PM
I've got good spark, but after reading some other ideas on the other newsgroup, think I might have ruined the plugs when it flooded. I'm going to try replacing them.
Ross.
Riverside, Ca.
1957 Provincial X2
1958 Transtar
1963 Lark. F.S.
Mark Anderson
1965 Cruiser
10-17-2006, 01:00 PM
What about the condensor?
And as to points, I've got about 4 sets of BRAND NEW Delco points in the garage that WILL NOT function if installed. Long story how I discovered this but I bought a whole box of these Delco tune-up kits (Points & condensor together) at an auction years ago and pulled some hair out the first time I installed a set!:( New stuff CAN be bad and can drive you NUTS:( trying to figure out what you're overlooking since you just installed brand new parts![xx(]
Miscreant adrift in
the BerStuda Triangle!!
52hawk
10-17-2006, 02:06 PM
I had a similar problem years ago. Finally found out the exhaust was plugged,the engine couldn't breathe. Try holding your hand over the tailpipe while someone else cranks the starter,you should feel a definite 'pulse'.
LaSalle,Il
61Hawk
60Lark
65cruiser
10-17-2006, 02:31 PM
Biggs, you were dead on:D. Actually Lee on the other board pointed me in this direction, but I actually think the condenser had failed. It looks like I had two separate failures (coil and condenser). At this point I replaced the plugs and points, condenser, and she fired right up.
Thanks everyone for the ideas! I would have never suspected a stinkin set of points and condenser that looked just fine. I mean, the points were "pointing", what else is there[}:)]?
Miscreant adrift in
Mark Anderson
1965 Cruiser
