View Full Version : heater motor circuit -a little stumped
10-15-2006, 04:52 PM
Scott,
It gets it's power from the ACC terminal of the Ign Sw. anyway, so if you go around the suspected bad wire section you won't be doing a bogus fix.
After 40 years of service, we shouldn't be surprized with things going belly-up.[xx(]
Miscreant adrift in
the BerStuda Triangle!!
Scott
10-15-2006, 05:20 PM
I lost power to my heater fan (1966 Cruiser) a year or so ago and I've been doing some troubleshooting on it for a while. I have determined the motor is good, the switch is good, the wire to the fuse is good and the 14 amp fuse is good. I have not checked farther than that, but has anyone ever encoutered a failure farther up the wiring harness like at the splice? It gets harder and harder to trail the wires as the snake their way around the back of the dashboard. I am getting tempted to rig up wiring from some other point, but I'm not sure where a good made-up splice could be. The easiest would be from the same point as the clock power from the ignition switch, but that might have hidden dangers (although I would be retaining the fuse).
I'm just a little stumped because the wiring is not easy to follow or repair farther into the wiring harness and I'm surprised that the fault could be where it appears to be and not in the more likely spots. By the way it is NOT intermittent.
10-17-2006, 07:46 PM
Scott; it is not hard at all to trace the Orange wire and the Red wire from the fan to the switch. There are two bullet connectors tucked up above or behind the air distribution fibreglass long box across the firewall under the dash. Those two plugs sometimes come unplugged. These are not part of any harness and are easy to spot and check.
Rich.
Studebakers Northwest
Ferndale, WA
Scott
10-17-2006, 10:34 PM
Well I know the wires to the fan are fine because I checked them putting power directly to the switch through an alligator clip lead from the ACC on the ignition switch. The fault is delifinitely somewhere in the wire (gray or white with black?) on the other side of the fuse.
Scott
10-21-2006, 06:37 PM
After some missteps along the way I put in some new wiring from the ACC on the ignition switch to the power input on the heater switch. IT WORKS!
I discovered that among other issues, I had badly fatigued wires going into one side of the old fuse holder. Of course after I spliced it and all, it decided to break off. A short trip to NAPA and now I have some new wiring and a new fuse holder.
10-22-2006, 04:54 PM
Sounds good!:D
Miscreant adrift in
