I need to replace the rubber seals on the vent windows of my 55 Speedster. The door glass needs to be removed first, then the vent window.
I've done the following as noted in the 55 shop manual:
1. Removed the vent window stop.
2. Disengaged the regulator arm from the lift channel.
3. Removed the window frame stop bolt.
4. Removed the weather seal strips.
5. Lifted the glass up and....I cannot get it more than about two inches above the top of the vent window at which point it just will not move up any further regardless how hard I pull up.
Not specified in the manual, I have loosend the bottom and top rear guide bolts/screw.
I've run out of ideas as what's causing the sticking problem. Need suggestions as what I might be doing wrong and/or what to do next.
Thanks in advance for any comments/suggestions.
