63 Lark 2 door Coupe to HT?
  • 63 Lark 2 door Coupe to HT?
    OK, here's a real goofy question for ya'll. I really like the roofline on the 63 2 door post cars. I like them much better than the lines on the Hardtops. How difficult would it be to use a 2 door coupe body and convert it to a Hardtop? I figure the doors would be easy enough by using the moulding of the hardtop to trim out the top of the door frame. On the rear, though, could you use the mechanism from the hardtop rear window and have a rear window cut to fit the opening? How naive am I being?
    Am I the only one to ever contemplate something so crazy??
    sals54
    You'll need a HT pars car to do it. You'll need to cut the lip off the top of the hard top doors and weld it to the sedan to mount the moldings. Then move the rocker boxes from the floor over. Then modify the rear sail panel to accept the HT rear windows, then....just forget it.
    JDP/Maryland
    63 R2 SuperHawk (Caesar)
    spent to date $54664,75
    64 R2 GT (Sid)
    spent to date $62,839.60
    63 Lark 2 door
    57 wagon
    39 Coupe express
    JDP Maryland
      JDP/Maryland
      64 R2 GT (Sid)
      63 Lark 2 door
      57 wagon
      39 Coupe express
      JDP Maryland
        Thanks Nels
        So, if the rear windows are the same, how about the rear glass? Are they different?
        sals54
          Thanks Nels
          sals54
            JP, You're missing the main point. I like the "C" pillar on the coupe body. I just want to use the HT doors and have a rear window cut to match the existing opening already on the coupe body.
            sals54
              sals54
                Darn. Now I have to go out and compare the roof line of my my Daytona to the '63 Standard out back... Thanks Sal!
                Matthew Burnette
                '59 Scotsman
                '63 Daytona
                Hazlehurst, GA
                  Matthew Burnette
                  '59 Scotsman
                  '63 Daytona
                  Hazlehurst, GA
                    It's just my artistic eye that doesn't like the rear treatment on the HT Larks. The "C" pillar stands too vertical. The lines on the coupe are much more pleasing, but I like HTs better. I think it would look really cool to have a HT with the lines of the coupe. Does that make it about as clear as mud?
                    sals54
                      sals54
                        Easy enough if you don't need the rear glass to go up and down, but if you do, that's where you'll have some real engineering work. Compare the sedans window geometry to the HT.
                        JDP/Maryland
                        64 R2 GT (Sid)
                        63 Lark 2 door
                        57 wagon
                        39 Coupe express
                        JDP Maryland
                          JDP/Maryland
                          64 R2 GT (Sid)
                          63 Lark 2 door
                          57 wagon
                          39 Coupe express
                          JDP Maryland
                            Sal, are you basically wanting a 2 door sedan with hardtop doors? That could be done, easy enough... But removing the 'B' post, that'd be one to figure out..
                            Matthew Burnette
                            '59 Scotsman
                            '63 Daytona
                            Hazlehurst, GA
                              Matthew Burnette
                              '59 Scotsman
                              '63 Daytona
                              Hazlehurst, GA
