I've been working on this issue for a while - previous thread can be viewed here - 51 Champion
Installed a new manufactured replacement pump with a paper gasket. I also added a thin layer of RTV. System was filled with water/coolant and started the engine for the first time in months. Thought all was well until I noticed water leaking from the lower side of the pump. I believe the water is leaking from behind the bolt (see video link)
Is reinstalling the water pump my only option? I did try and re-tighten the bolt. The bolts are from the original failed pump. I didn't notice any leaks around other areas of the pump. Thanks in advance for suggestions.
Brett
Brett
