You know how a simple task can turn into a nightmare? Well, I created quite a situation for myself. The speedometer cable on my 1950 Champion was bouncing, so I decided to lube it. Simple job, right? I disconnected it at the tranny, pulled it out and up, ran some special speedo cable lube into it, worked it a little bit, and, with my son's help, started to slide it back down along the firewall to get it back in. That's when things went bad.
I apparently caught the cable on the OD relay. It created a direct short, apparently from the relay to ground on the body (not sure)and started cooking the cable and the fresh lube in it. By the time I scrambled out from under the car and disconnected the Neg. Battery cable, which was already loose (about ten seconds or so), smoke was bilowing from the lube cooking, the cable sheath was glowing red and kinked from the heat. Suffice to say that, even though the cable was ruined, I'm lucky I didn't burn up the whole car. Lesson learned there.
The problem I have now is that the overdrive doesn't work. The fuse on the OD relay is OK, but I assume I cooked it inside. How would you test one of these things with a multi-tester? Could I have damaged the solenoid or something else? Since the relay is a $95 part, I hate to replace it if I don't have to do so. Any advice is appreciated as always.
1950 Champion
Holdrege NE
1950 Champion
Holdrege NE
