Is there someone in our Studebaker community who can cut keys using the key numbers from a production order?
Cutting keys from Key numbers on production orders
'58 Packard Hawk. A partially restored car that was not completely assembled.Tags: None
The Older Locksmith Shops can do that for you, if they still have the old conversion charts.
The easiest, cheapest and best method if you can, is just have a good working Key Copied onto a New Studebaker Vendor Key Blank.
If you have the Production Order Key Codes, you cannot always be sure the Car still has all 5 of those same locks.StudeRich
Originally posted by StudeRich View Post... you cannot always be sure the Car still has all 5 of those same locks.
Except in the case of most trucks and earlier cars that did not have a keyed door lock on the driver side. Those only had 4 tumblers.Brad Johnson,
'56 Sky Hawk in process
