View Full Version : Rear Axle: Rear axle splines
chrise2
01-05-2019, 11:27 AM
I have a 67 Avanti. What number of axle splines does it have?
thanks in advance
bezhawk
01-05-2019, 02:46 PM
Studebaker used 19 splines. The later Avantis used a finer spline, but not sure when they changed. You might pull one to be sure. It's good to do to repack the outer wheel bearings anyway.
StudeNorm
01-05-2019, 03:11 PM
I believe flanged axles were 31 splines. My '63 has tapered axles and 19 splines. I think '67's were flanged. If you have a big nut holding the axle in you have tapered. No nut---flanged.
studebakerkid
01-16-2019, 04:13 AM
You might as well put zerks in to make packing the outer bearings much easier too. Think I wrote up the procedure a deckade or more ago and posted it here.
jpepper
01-16-2019, 10:53 AM
My 66 had tapered axles with 19 splines like Studebaker. Avanti used a HD Dana 44 with 30 spline axles around 1970 and up. 67 to 69 might have used the 65/66 Studebaker flanged axle rear end with 27 spline axles. The key is whether it has flanged or tapered axles. An early 67 might still be tapered.
