View Full Version : Electrical: Parts Identification......
Lou Van Anne
12-15-2018, 09:51 PM
77584Can anyone identify this? The Antenna connects to it, one cable goes to the radio, the second goes nowhere....79 Avanti II. I'm thinking this has been the source of my static problems.....
(S)
12-15-2018, 10:44 PM
Looks like a noise device. One side should be ANT> IN one side goes >OUT, to the radio. If that has a regular looking wire coming out of it it goes to ground, or it won't work.
bensherb
12-15-2018, 11:07 PM
Could be an antenna booster. Same deal, one cable from antenna, one to radio, but wire goes to power.
graylark
12-16-2018, 05:39 AM
A long time ago I saw a device that looked exactly like that which allowed you to connect your car radio antenna to a CB radio so both radios could work off of the one antenna.
Bud
12-16-2018, 07:34 AM
I agree with graylark, It sure looks like the adapters used in the 70's and 80's to allow the use of a CB radio on the existing auto radio antenna. Usually noise suppressors would be used on the 12 volt input lead to the radio and not the antenna lead. Bud
graylark
12-16-2018, 02:29 PM
In the world of RF its taboo to leave an open port on a device such as a combiner like you have unless you terminate it with a dummy load. You don't need it, remove it and plug the antenna directly into the radio and see if it helps.
Bud
12-16-2018, 03:59 PM
I remember those radio/CB adaptors didn't work well for either the car's radio or the CB as they reduced the signal to the radio and the CB radio didn't work too well either being loaded into an auto radio antenna. Graylark is right again, take that thing out of the antenna circuit and the auto radio will work much better. Bud
Lou Van Anne
12-16-2018, 08:37 PM
Thanks everyone....sounds like we may have a solution here. I'll try it tomorrow and post the results.
(S)
12-16-2018, 09:06 PM
The writing on it looks perfectly clear. What does it say? google
Lou Van Anne
12-16-2018, 09:47 PM
All it says is "Tune" and apparently a part number.....
Bud
12-17-2018, 07:43 AM
If your part has an SO239 connector which is a screw on type used for transmitting type antennas, then it is an antenna splitter and should be removed from the antenna circuit to your radio. Bud
Lou Van Anne
12-17-2018, 07:11 PM
PROBLEM SOLVED: I removed the antenna splitter, put a new connector on the antenna cable and no more static! Finally!
