View Full Version : Engine: Piston Help
Bamajak
12-06-2018, 06:57 PM
I have a set of pistons flat top supposed to R1 part number 1557714 30 over 3.5937 inches. Can anyone verify or identify this piston set?
rbisacca
12-06-2018, 09:45 PM
Where did you get that part number? Avanti parts book shows part number 1557858 to be .30 over R1, R2
Bamajak
12-07-2018, 08:00 AM
Printed on the box the pistons came in..................
rbisacca
12-07-2018, 12:12 PM
None of my parts books nor my Price Book show this number. So this is a GUESS. All my parts books show pistons individully not as sets. Perhaps after the parts books were published the decision was made to package the pistons as sets and this number was given to a set of 8. Remember, this is just a GUESS.
dpson
12-07-2018, 02:25 PM
Is there a casting number on the inside of the pistons?
12-07-2018, 02:54 PM
The 1557858 is also the correct R1/R2 Jet Thrust .030 Over Piston listed in the Jet Thrust Engine Equipment section of the '59-'64 Chassis Parts Catalog.
There were NO "Sets", Pistons were sold Per One of 8 needed.
I thought MAYBE, since the '59-'64 Lark/Hawk Chassis Parts Catalog and the Avanti Parts Catalog were printed at different times that there COULD be a discrepancy between the two, but NOT.
Does anyone have the Late 1963 or 1964 Printing of the: "Parts and Accessory Price List" -Book "F" ?
Later Parts and Superseded Part Numbers can be found there. ;)
Bamajak
12-07-2018, 03:04 PM
This is the casting number and the manufacture is BOHNAN I think another cast GE3550?
(S)
12-07-2018, 03:28 PM
Those are in the wrong box most likely. The popular, cheaper Stude piston is 3550, from A Ford. I have heard of many using them, only know of one personally, it ran good on Super.
Dwain G.
12-07-2018, 06:28 PM
So 1557714 is cast inside the piston?
12-07-2018, 07:20 PM
I was "Told" for what it is worth, that the Avanti R1/R2 Piston replacements some have used, are for a V6 Ford and they do give higher Compression than a stock dished 289 Piston because they are Flattops, but the Pins of course are not the bolted to the Rods Type requiring some machining/Pin Fitting to make them safely work.
You do have to wonder what kind of Deck Clearance you would get, with the wrong pistons. ;)
Bamajak
12-07-2018, 08:35 PM
Yes 1557714 also GE3550 plus another number after 3550 I can not read
Dwain G.
12-07-2018, 10:25 PM
Ok then, that is just a casting number so it won't appear in any book. It is probably on a blueprint though.
rbisacca
12-07-2018, 10:57 PM
I have the September 1, 1963 printing of the "Parts and Accessory Price List"-Book "F" It does not show PN 1557714
Skip Lackie
12-08-2018, 07:46 AM
Just for the record, 1557714 does not appear in the 1968, 69, and 71 price lists.
