Can anyone post a photo of a 53 Commander Coupe dash? Left side of the gauges. Thanks
53 Commander coupe dash photo
Its set up like a 57-58 Hawk and has a clock where i'd put a tach. I'm no expert on them. 1956-61 are about the same and commonly put into 53-54 C/K for an easy 12V conversion and also because the SW gauges and machine turned panels are just too cool..
That one has a Red Dash, the Color coded dashes started in 1959, and the Steering wheel and other Steering Column components are 1957 and later type.
There is a cutout in the Fiberglass for the Clock to be over between the Radio and Glove Box, so a Tach. can go in the hole that Clock is in if desired.
Since all C and K Bodies have the same Cowl and Windshield, many have different year dashes installed.StudeRich
Originally posted by tim333 View PostReally Nox? Do you think what you see is accurate? You won’t get correct info like what Studerich gracefully supplies. I purchased a 53 sales brochure off Ebay and the picture I have in post #3 didn’t look like the brochure, hence my question.sigpic1957 Golden Hawk
The picture in the brochure was very small, not clear and didn’t match the screenshot of the dash in the 53 Commander I was considering buying. It’s just as easy to ask here as it is to Google and the info here I consider accurate. So he’s not rude telling me I should Google?? I like sharing thoughts with club members, that’s why I joined. Always find help and good advice.
I think the '56 dash had a third toggle switch instead of the slider, to the left of the steering column. The '58 to '61 Hawk had a simple cutout for the radio, like in Tim's photo above. The '56 & '57 require a face plate. All have the fiberglass cut out for a small vac. or vac./press. gauge above the steering column. Which was used on Golden Hawks.
