Greetings. any hints for installing windshield and back glass on 1949 C cab 1/2 ton truck?
Studebaker truck windshield install
Originally posted by davidj View PostGreetings. any hints for installing windshield and back glass on 1949 C cab 1/2 ton truck?sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
I still have that job to do on my truck so I can't speak from experience, but I would welcome any tips also. I do know that you need to be careful to install the rubber around the back glass the correct side out. I have seen some installed wrong."In the heart of Arkansas."
Gary Ash
Dartmouth, Mass.
’41 Commander Land Cruiser
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
Cut yourself a couple of wooden wedges to keep the two piece windshield spaced in the middle . If you don’t use them the glass will have a tendency to push together in the center and you want a gap there to accommodate the center strip.sigpic
I have installed 2 using poly baler twine and stopcock grease. I stays the same viscosity over a huge temp range and never hardens. The poly twine is slippery. So far no leaks. It is about $18 for a 60g tube . you'll need 2. It is Dow Corning stopcock or vacuum grease pn 146355D (and ,of course, the price has gone up!)Last edited by Jeffry Cassel; 11-11-2018, 02:06 PM.
