Our 54 commander runs beautifully and idles perfect in Park. When you pull it into gear and hold the brake like you were sitting at a stop light, the RPM drops way down and then when you try to take off and give it gas, the engine dies unless you gently pat the throttle to get the RPM to come back up. If you just give it the gas as you would expect, it will choke off every time.
I have run the normal idle adjustment up until I am out of adjusting screw. It raises the idle RPM when in park but as soon as I put it in gear the rpm drops way down again and you have a hard time taking off from a stop without the car cutting off.
I assume I am doing something wrong here. There must be another adjustment somewhere, or maybe there is something about the trans that needs to be adjusted. This car is stock with the original automatic trans.
Please educate me on what I am doing wrong.
Wayne
Wayne
