A now have a couple of new issues. I was cruising along and the speedometer made a horrible whine and grind noise then the needle buried all the way right and disappeared. I disconnected the cable from the back but the needle has not returned. I have not taken the unit out yet. Is this a lost cause on the speedo or is it just stuck?
Second I am still having engine issues. The dwell is 26.9, timing is at the G in the ign section. There are no numbers to base timing on. I have tried timing in different spots to see if there is any difference. Carb is rebuilt correct carb. Fuel pressure is good. Mechanical pump works and I have a electric backup that works well. Does not appear to be any vacuum leaks(tested with carb cleaner). Idle is at 620rpm. Problem is lack of acceleration and carb backfire. The car bogs down when floored. I have discussed some of the issues and I have tried many suggestions. I just cannot get it dialed in. The lash is correct. I continue to ask for ideas.
