Got Bess ('56 Parkview Commander, stock) running again yesterday. She's running nicely although one of the valves still appears to be sticking. It seems to be working the issue out itself as the motor is running much nicer now. However when I switched the engine off, the amp light remained on. Also the pair of wires on the right side of the regulator were hot as well as the thick, white wire on the Genny. Disconnected the battery terminal as things were smelling a bit hotter than desirable. Also noticed I have to replace the wire from the solenoid to the starter, it's looking very frayed.
Do I have a bad regulator (replaced in '06) or maybe a stuck switch somewhere?
