I Have developed a sharp rapping noise from my 64 Hawk engine! It comes and goes mostly at lower rpms and it quite loud. Almost like a very loud paint can rattle. It also seems to come and go as I go around curves as if the engine is shifting a bit. It also is most pronounced at idle with car not moving but also comes and goes then. Help please! Thanks to all. M.hopinfox. Kennesaw, Ga.
Engine rapping noise
Fan hitting the shroud because of a broken mount or cracked flex plate ?
JDP/Maryland
63 R2 SuperHawk (Caesar)
spent to date $54664,75
64 R2 GT (Sid)
spent to date $62,839.60
63 Lark 2 door
57 wagon
51 Commander
39 Coupe express
39 Coupe express (rod)
JDP Maryland
Inspect it through the hole in the right side of the Torque Converter Housing by removing the stone shield. This is only going to happen with an Automatic Trans.
It also could be the throttle pressure control valve rattling, because of low Trans. Oil or improperly adjusted pressure rod which can be caused by worn rear engine (Trans) mounts.
Studebakers Northwest
Ferndale, WAStudeRich
If it were an Avanti, I'd say the left exhaust manifold was hitting the steering box. Check the exhaust carefully. Hold the brakes and load the torque converter. Have someone standing clear look for fan, exhaust and other interference.
thnx, jack vines
PackardV8PackardV8
Thanks for all the advice. It is an automatic and the Transmission is in need of service. There is a local mechanic familiar with these cars and will look at it in a few days. Thanks to all. I'll report on cause/fix. M.hopinfox
