I was looking over the shop manual instructions on checking a block and pistons for wear and deciding between refresh or rebuild. I have read the sections a number of times and perhaps I am overthinking what the shop manual says...
On page 32 of the v8 section of the Lark shop manual there is an illustration of an upside down piston in the bore with the mechanic using a feeler gauge and a spring scale. if the pull on the feeler gauge does not fall within a given range, clean up the bore and try again or eventually replace the piston
My questions here are why am I doing this and where does one get the tools to do this test.
A few pages later on page 35 it looks like a dial indicator on some sort of handle to check taper. I think I can get a dial indicator almost anywhere but what do you do for the handle or should I see about borrowing a micrometer and using a telescoping T gadget.
I've pulled apart and rebuilt a number of engines over the years and I have usually just let the machine shop do all of this but those were the days when I was single
Well any advice anyone can give
Jeff T.
"I'm getting nowhere as fast as I can"
The Replacements.
Jeff T.
The Replacements.
