Ok you guys. You have always gave me good advice to this point.
On my 56 2dr Champion sedan. My fuel gauge has NEVER worked right o n this car.
Here is the situation.
I only have one wire to the tank. The Gauge reads full with the key on and wire on sending unit connected.
If I disconnect wire on sending unit it goes to 1/2 full even with key on. So I thought maybe I had wires reversed on gauge. I switched the wires and reconnected to sending unit and now the gauge shows full again, even though I have driven 139 miles on this fillup
Any other suggestions or recommendations to check? Is there a way to check the gauge with a volt meter?
I am open to all suggestions
Again Thank you for all of your advise in advance.
