On my way home from Summit Studebaker/Packard Show on Saturday, after the last fill up, the gas gauge stayed at the empty level, even though I knew the tank was full. Where should I start looking, electrical or tank float or whatever?
Gas gauge died
Tags: None
And your tank could have lost its ground. that sending unit is a variable ground and must have a good connection to the tank which in turn grounds to the frame..... if a bad ground is suspected a long jumper wire to negative side of batt. will tell the tale. when i have this problem i install star washers on the side of the tank with 2 mounting points after shining up the tank and frame mounting areas. i lucked onto an assortment of quality star washers at a flea market decades ago. Over the years i have had problems with cleaned frame areas turning black after a while and losing continuity as a ground, whats up with that? Luck Doofus
Last time that happened to me the ethanol fuel had consumed the shellac covering the cork float, the cork then deteriorated to the point where it dislodged from the hanger and fell to the bottom of the tank.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
