View Full Version : Wonder if any of these wagons are Studebakers
hausdok
08-27-2018, 04:12 PM
https://www.auctionzip.com/Listings/3131218.html?email=68617573646f6b406d736e2e636f6d&utm_source=house&utm_medium=email&utm_campaign=exclusive&utm_content=mar082618
StudeNewby
08-27-2018, 05:07 PM
I see several other manufacturers' tags, but no Studebakers. Can someone tell us if there are distinguishing marks to look for?
Guido
08-27-2018, 09:06 PM
The auctioneers are well known in the carriage and buggy world.
Guido
08-27-2018, 09:09 PM
Many time the axle ends are marked, you need to remove a wheel to see. It is imperfect as Studebaker sold axles to other manufacturers. On wagons the design of the hubs and spokes is a clue.
57pack
08-27-2018, 09:12 PM
IF I recall correctly, Studebaker wagons and carriages had a distinctive wheel construction design.
The spokes were notched into the wheel.
studeclunker
08-28-2018, 03:13 PM
The Studebaker spoke design is not a good test anymore either. They didn't patent the wheels and allowed other manufacturers to freely copy their design. Also, on a lot of vehicles the wheels have long since been replaced. I can see at least six vehicles that might be Studebakers. However they were all common designs. That Rockaway though is very, very similar to a genuine Studebaker I have seen in someone else's carriage house. Another place to look is on the front edge of the front seat, under the cushion. There might be a round button placed there by the distribution centre. however a high-end vehicle like that Rockaway and the drop-front (phaeton) buggy usually had grease, or hub, caps that bore the Studebaker name. As has been mentioned here, chassis iron is not a perfect place to check, however any reach-type vehicle will have Studebaker cast into the Fifth-wheel and those were only used for Studebakers. Sometimes it was also embossed on the reach(es), once again only on a Studebaker high-end vehicle.
About the button under the front seat: This was a uniquely Studebaker thing. So if you pull up a seat cushion and find a (nickle-sized) circle impressed into the front seat frame with a nail hole in the middle, chances are you have found a Studebaker.
