View Full Version : what transmission is this?
mbstude
02-09-2008, 03:26 PM
Can anybody tell me what it came in? It has cooling lines and the underhood dipstick. Thanks in advance. :)
http://i81.photobucket.com/albums/j209/mbstude/boneyard/boneyard014.jpg
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
http://i81.photobucket.com/albums/j209/mbstude/avatar-7.jpg
N8N
02-09-2008, 03:31 PM
I can't say for sure, because I can't see pics from work (yes, on a Saturday,) but I assume that this is a Studebaker automatic. cooler lines are either a HD FOM or a PS, underhood dipstick means either a long-tail, single piece driveshaft model or else someone just swapped the 'stick into an early case. How many detents on the shift lever? PNDLR is a HD FOM, PRND21 is a PS.
N8N
mbstude
02-09-2008, 03:42 PM
Didn't check the # of detents. [:I] Long tail shaft; cast iron case with aluminum tail shaft. The numbers are AS12-5P.
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
mbstude
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
55studeman
02-09-2008, 04:00 PM
Have you tried looking up the stude number on the id plate, where it says "Mfd. for Studebaker Corp. their no. 1563_ _ _." Can't see the last three numbers, the paint is obscuring it in the photo, but you should be able to make it out by feeling it or rubbing the paint off. Look up that 1563_ _ _ number in the parts cataloges.
Also, see the patent numbers? You should be able to do a google search on those and you'll probably get a hit on at least one of them.
Best Regards,
Eric West
"The Speedster Kid"
Sunny Northern California
Where the roads don't freeze over and the heat doesn't kill you.
And an open road is yours to have -only during non-commute rush hours 9am-4pm and 7pm to 7am (Ha, ha, ha)
55 Speedster "Lemon/Lime" (Beautiful)
55 President State Sedan (Rusty original, but runs great and reliable)
55studeman
Best Regards,
Eric West
"The Speedster Kid"
Dwain G.
02-09-2008, 04:10 PM
The AS12-5P and the 1563--- is enough to identify it as a '65-'66 V8 trans.
http://home.comcast.net/~jdwain/images/63.63.jpg
Dwain G.
Dwain G.
Dwain G.
mbstude
02-09-2008, 04:26 PM
Thanks Dwain. :)
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
mbstude
Thanks Dwain. :)
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
02-09-2008, 05:01 PM
Matt; that one is going to have the 2 cooling line fittings on the right side just above the pan, because it is a HD Trans. but it's throttle press. control is cable operated not lever operated, so it's a bit different than '58-'64 Flight-O's it does still have a second gear start though.
Studebakers Northwest
Ferndale, WA
Ferndale, WA
mbstude
02-09-2008, 05:07 PM
quote:Matt; that one is going to have the 2 cooling line fittings on the right side just above the pan, because it is a HD Trans. but it's throttle press. control is cable operated not lever operated
Yep, that's it! The cable threw us off, but we knew it was HD by looking at the cooling line fittings. And now we know. :) Thanks fellas.
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
mbstude
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
