View Full Version : Keeper of the temp-lets?
Hawklover
08-18-2018, 10:56 AM
I am aware of the fact that someone on this board is the person to contact concerning getting copies of Studebaker temp-lets and other copies of Studebaker "kits" that dealers installed at their shops.
Thanks in advance for the contact information.
showbizkid
08-18-2018, 02:21 PM
See here: http://studebakerdriversclub.com/officers.asp#other
Bottom of the page - it's Andy Beckman at the SNM that you want to contact.
08-18-2018, 04:07 PM
temp-lets had me going, but templates I grok. Now, if someone would elucidate on how templates relate to dealer installed kits? OK, first guess; one template could be the guide as to where to drill the hole for a radio antenna? Back when, radios were exotic and expensive accessories and not every dealer had installed one.
jack vines
08-18-2018, 05:48 PM
For True Jack, and not every Dealer's Service Dept. Tech. payed ANY attention to the Accessory Directions and Templates either.
Especially the Idiots that would drill a hole in the Right Fender for an Antenna or sometimes got close using the Left one, but not into the Cowl! :(
I have even seen several East Coast Cars with the Antenna drilled only into the Cowl up close to the windshield, that made for the EASIEST Cable routing, straight to the Radio but would cause a direct heavy water path/leak as well as being in the Driver's field of view.
rockne10
08-18-2018, 05:49 PM
jack vinesHeinlein reference is noted and appreciated! ;)
Now, if someone would elucidate on how templates relate to dealer installed kits? OK, first guess; one template could be the guide as to where to drill the hole for a radio antenna? Back when, radios were exotic and expensive accessories and not every dealer had installed one. ding, ding, ding! We have a winner! :!:
rockne10
08-18-2018, 05:53 PM
I have even seen several East Coast Cars with the Antenna drilled only into the Cowl up close to the windshield, that made for the EASIEST Cable routing, straight to the Radio but would cause a direct heavy water path/leak as well as being in the Driver's field of view.When I bought my '53 as a daily driver over four decades ago it had been so desecrated. The error was corrected some thirty years later.
Mrs K Corbin
08-20-2018, 06:47 AM
What's worse is I probably Desecrated mine, as I copied another truck with the radio ant in the right fender.
Hawklover
08-20-2018, 07:55 AM
Jack, many thanks for the proper word, LOL... The "template" or instructions in this case concern Studebaker a/c kit # AC-3469 for Avanti models.
jack vines
rkapteyn
08-20-2018, 08:54 AM
74942http://studebakerdriversclub.com/Studebakertemplates.asp
Hawklover
08-20-2018, 05:19 PM
Thank you!
