View Full Version : Progress
bezhawk
08-14-2018, 05:42 PM
Some engine, and frame pics of my latest project. Almost finished with the running gear. The body is coming along too. I hope to be in primer by the end of the month.747877478874789
64V-K7
08-14-2018, 05:52 PM
R-3354? ... ... ... ... ... ... ...
bezhawk
08-14-2018, 07:18 PM
Not necessarily.....I have seen many bellhousings painted with numbers other than the body number, or serial number. The engine number does match the production order.
Colgate Studebaker
08-14-2018, 08:19 PM
Just beautiful Brad!
08-14-2018, 08:28 PM
Usually it is the "Line Number" on the Car and Truck Line. On the Avanti line, maybe.
WCP
08-15-2018, 12:44 PM
Yes, to the line number for Avantis.
63r2
08-15-2018, 05:55 PM
So you can put all that engine stuff on without affecting the body drop but not the supercharger is that correct ?
bezhawk
08-15-2018, 06:55 PM
Right, It is tight, but it's possible if you take it really slow, I also support the body on the hog troughs with the arms of the lift unlocked. I can shift the body up to two inches side to side as it is lowered. It only has to line up with the body mounts during the last inch and a half of the lowering. Also the frame is on wheels and tires able to roll back and forth. ( Go-Jacks also help). Theore support has to be mounted to the body before the drop, as you can't put it in after the drop.
raprice
08-16-2018, 11:21 AM
Beautiful job!!!
