View Full Version : Engine ID help.
Mrkelly
08-11-2018, 06:16 PM
Can an anyone help me ID this Studebaker V8. I wanting to know the year and 259 or 289. Your help is appreciated.
74498
Mrkelly
08-11-2018, 07:24 PM
I trying to determine if that is a 1 or a L after the P .
studegary
08-11-2018, 07:28 PM
That is a 1.
08-11-2018, 07:41 PM
It would be Number: 14,644 289 ("P")
The South Bend assembled 1963 289 Engines started at 93,601 so it is too LOW!
The Los Angeles assembled '56 President 289's started at: PL2701
OPPS, Wait a minute! :ohmy: That MUST be a poorly stamped "L" making it PL4,644, the Turquoise Paint also matches a 1956 President Engine!
http://www.studebakerdriversclub.com/V8EngineID.asp
If it has a Bi-pass Oil filter or None, without the Full Flow Oil Filter at the Lower, Right Rear, that is definitely a 1956 289.
Also the Casting Number at the Right Front side of the Car & Block, would be a SIX Digit 5XXXXX Number not a Seven Digit 15XXXXX.
studegary
08-11-2018, 08:07 PM
Perhaps it is a replacement block not stamped at the factory and they used a 1 instead of an I.
EDIT: I agree that things like the location of an oil filter would separate the 1956 from the 1963.
08-11-2018, 08:13 PM
Yeah BUT, if it is a "1", The Serial is TOO Low to be a 1963!
Without the Decimal Dude's Help, I THINK that is correct! :confused:
Dwain G.
I go with Rich on this one. Especially since that is not a proper 'I' (1). A little scraping and wire brushing might help.
Mrkelly
08-11-2018, 08:20 PM
This is a photo of the engine, it has 289 decals on the rocker covers but I wasn’t sure it really was. Anyone can apply a decal and call it what they want.
74501
studegary
08-11-2018, 08:23 PM
I agree. I was too hasty. If it is P1---, it is a 1955 President 259 cid V8.
Mrkelly
08-11-2018, 08:32 PM
Another shot of the engine. It’s in a 1961 Champ.
74504
08-11-2018, 08:47 PM
It does have the Bi-pass, drop-in Cartridge Fram Type Oil Filter on top, so if there is none on the bottom, clearly a 1956.
I would guess that the Truck is probably a 6E5 6 Cylinder Truck, but COULD be a 6E7 with just another V8 replacement.
Mrkelly
08-11-2018, 09:05 PM
So it’s my understanding that even though it’s being represented as a 289, and by motor number it is actually a 259. Am I correct?
studegary
08-11-2018, 09:46 PM
Yes and No. The engine block started out as a 259 cid. It may now be a 289 (utilizing 289 crank and pistons) or it may still be a 259. It is what is inside that makes the difference. After 63 years, it would have to be investigated. It is simple enough to measure the stroke by just removing a spark plug and measuring the difference in piston location, top of stroke to bottom of stroke.
studegary
08-11-2018, 09:47 PM
Did I misread something else? Why do you call it a 1956 and not a 1955 President 259?
EDIT: 1956 President engines start at 22,001 and this engine appears to me to be 14,644.
6hk71400
08-11-2018, 10:54 PM
I will go out in the morning and look at the motor number on my 1955 President Speedster. It was assembled in South Bend and was shipped to Danube MN. It is a 259 with a "P" starting number.
Bob Miles
08-12-2018, 01:14 AM
Is it actually possible that they built 14,543 1955 President 259 Engines?
But if THAT is possible, then I guess it would have to be a badly struck "I", and it shows no signs of the crosses at the top or bottom. :confused:
It seems more believable that they built 1,943 Los Angeles "PL" 1956 President 289's.
But I do know how to solve the Block's true Identity, just check the DATE Code near the Distributor. They are RAISED Numbers & Letters on the Right Rear, Bell Housing mounting Extension.
altair
08-12-2018, 10:48 AM
Is it possible, that symbol behind the P is merely a scratch in the block and we are over reading in to it and the actual number is "4644". 55 Presidents started at P101 and 56 presidents started at P22,001 therefore it is conceivable that it is a 1955 year engine. The 1955 President was a 259 and the 1956 President was 289. For this engine to be a 289 it would have a stamped number in greater than 22,000. The determined number being P 4644 would fit as a 55. And likewise "14644" would also fit as a 55 but somewhat later. The engine color is close to Azore green that was available in 1954 as this engine was probably built in 1954 that color was readily available.
08-12-2018, 01:06 PM
Without checking the Build Date, it's all conjecture.
That "L", "I" or "1" is clearly a Stamped mark, and most resembles an L.
The Engine paint is 1956 & 1957 Engine Turquoise Green, all '47 to '54 Engines were Olive Green.
Jeffry Cassel
08-12-2018, 01:31 PM
It is a 1955 engine and probably a 259. 1956 appears to have begun with SN P-22001 so P-14644 is lower and per altair isw a 1955 259cid motor. Color doesn't mean much--- rattle cans
64studeavanti
08-12-2018, 02:43 PM
I agree with this starting out as a 55 259. I have a speedster with engine #P16246
studegary
08-12-2018, 08:08 PM
Why wouldn't it be possible that they built 14,543 1955 President 259 engines? They built 24,664 1955 Presidents.
6hk71400
08-15-2018, 05:48 PM
Bob Miles
Well, after much moving around and other delays, the engine number on my 55 Speedster is P16689 and was assembled in South Bend on 4-24-1955. This car has the optional 8.00 heads
Hope this helps out.
Bob Miles
