Car: 1951 Studebaker Commander Land Cruiser
Engine: 232 V8
Transmission: Automatic Drive DG200 (don't quote me on this, as I will have to verify if it is a DG200)
Fluid Level: Full, fluid was replaced a month ago
Fluid Type: Type F Valvoline
Disclaimer: I don't claim to know much about these transmissions even with the shop manual dedicated to these marvels. The problems arises when I am shifting the vehicle either form:
- Neutral (N) to Drive (D)
- Drive (D) to Neutral (N)
- Low (L) to Reverse (R)
- Reverse (R) to Low (L)
When the shifting is executed there is a slipping/grinding sound. It feels like the transmission is searching for the right place to drop the gear. Sometimes this will go on for about 5 seconds before the transmission "pops" into gear. See the link below of an example of when the transmission is shifted from Low (L) to Reverse (R). The issue is intermittent and appears to be more common when the car has not had a chance to warm up. I apologize for not being able to provide more description and would appreciate any direction.
Link:
Engine: 232 V8
Link:
