Big shout out to all the guys that have been giving me assistance. The 51 is now drivable. She idles at a smooth 650rpm , timed, no smoke on start up or running. Only the occasional oil drip. No drip out of blowby tube. fuel pressure is good, upper fuel lines are insulated to hopefully prevent vapor lock, gas tank has been lined with KBS coating and does not leak. fuel gauge and sender now work. All gauges now work, including clock. Speedometer works, albeit a little jittery, will use graphite on it later. All fluids and grease have been replaced. Brakes upgraded to newer Studebaker brakes. Transmission works perfect, shifting up and down now, no shudder. Leaks a little but I will take that for now. All electrical works as it should. Steering box repacked in corn head grease and moves smoothly. Turn signals work. All in all very happy now with the progress. Need to finish the interior and buff out the outside(need a touch up on the roof) and she (Gracie) will make a solid driver.
Jim
Jim
