View Full Version : Stromberg Carburetor (pictures)
Randy_G
02-06-2008, 10:55 PM
I know I have been on this topic before and JDP has even sent me what should have cured my problems. However I have the same dilemma, I have an rebuilt Stomberg Carb (6-123) on my Lark that works great, but I dont have an air cleaner that will fit it. After a little research I have found out it came off an 259 V-8 1955-1964 truck. I don't mind that it came off a truck but I need to get an air cleaner to work on it regardless and right now I don't have anything that will work.
Photo 1. This carb (6-123) is what's on the Lark.
http://www.automotivehistoryonline.com/024.jpg
Photo 2. This a picture of the carb LStude sent me to show me what I'm supposed to have on the Lark. Note the difference in the ring around the air intake.
http://www.automotivehistoryonline.com/025.jpg
I would gladly trade someone even for a carb that will fit my air cleaner or if you have an air cleaner that I can attach to this one we can talk about price. It's just one more piece in the puzzle to get this Studebaker back on the road.
Randy_G
1959 Lark Sedan
www.AutomotiveHistoryOnline.com
http://www.automotivehistoryonline.com/emtr.jpg
JDP
02-06-2008, 11:08 PM
Well, I can send you a truck air cleaner, but you'll need to cut a hole in the hood.:) I have a bunch of good used Lark carbs, but they'd all need a kit.
JDP/Maryland
63 R2 SuperHawk (Caesar)
spent to date $54664,75
64 R2 GT (Sid)
spent to date $62,839.60
63 Lark 2 door
57 wagon
51 Commander
39 Coupe express
39 Coupe express (rod)
Dwain G.
02-07-2008, 01:33 AM
A 6-123 is actually correct for a '59 Lark. The carb in the lower photo is probably a 6-130. Notice the low-mount choke and PCV tube at rear of throttle body.
Do you know the part number of your air cleaner? I'm thinking it's a dry unit, is that correct? I think you need an adapter that looks like a round tube with a long 1/4" stud attached, and a clamp to lock it to the air horn.
http://home.comcast.net/~jdwain/images/63.63.jpg
Dwain G.
02-07-2008, 02:50 PM
You have the correct Carb. for a '59-'60 Lark 8, you just need the air cleaner with the clamp and screw fastener, both wet & dry types were used instead of the center wing nut and stud. S.I. sells an adapter to put a '64 flat flange air cleaner on your 6-123 Carb. Or if you put Leonards on there, keep in mind it is a low choke not a high choke like your intake manifold was designed for! Choke heater tube is wrong! Then you would need a '64 air cleaner.
02-07-2008, 09:18 PM
For 59 Lark 2bbl carbs, adapter 1549361 was used. It adapts the '59-'60 air cleaner to that bevel-topped WW carb. That adapter's available from SASCO for about $21 bucks and shipping. 1551977 works with the '61 air cleaner. It's also available from SASCO for the same price.:)
Miscreant adrift in
the BerStuda Triangle
Randy_G
02-08-2008, 12:46 PM
Miscreant adrift in
I ordered one of these today from SASCO, I hope this correct's my problem, I will be sending JDP's back to him and my other one I bought I may put on on e-bay. Thanks for all the help guys.
Randy_G
1959 Lark Sedan
