View Full Version : Fuel System: Fuel pump cam lever pin not moving...
62champ
07-02-2018, 03:24 PM
Very generous friend has furnished me with a used Carter 2573-S fuel pump to get the Champ back on the road. Having some trouble with the cam lever pin not wanting to come out - but I don't want to talk about twisting off three of the main body screws...
According to the shop manual, you removed the pin plug from the housing (done), removed cam return spring (piece of cake). It then states to remove the pin retainer (spring clip) and remove the pin from the housing. My cam lever does not have this pin retainer. Shop manual shows the retainer over the pin in the middle of the pin behind the return spring. My rebuild kit that arrived today had a replacement pin with a groove in the middle and the retainer clip to go there.
https://i.imgur.com/BJSq0zV.jpg?1
My thought was maybe this particular pump did not have the retainer and getting the pin out is a simple matter of tapping it out the large end where the lead plug was located. Smallest thing I have is a rat tailed file that will fit in the small hole side of the housing to tap the pin out. At this point, I have hit that end of the pin a dozen times and only managed to start to mushroom the square end of the file...keep running that saying though my mind about a 20 minute job is something getting broken away from turning into a three day ordeal...
Any insight? And thanks ahead.
RadioRoy
07-02-2018, 06:21 PM
Why not just leave it alone? You can rebuild the diaphragm part of the pump and leave the lever pin in place.
mbstude
07-02-2018, 07:04 PM
I rebuilt a V8 pump a couple of weeks ago that was stubborn like that one. I put the pump housing in a vice. Then clamped a small pair of vise grips on the pin, inside of the arm, and used a hammer to tap on the vice grips. Eventually it moved and I was able to “walk” the pin out.
07-03-2018, 02:30 AM
A Carter 2573-S sure does not ring a bell as being for a Stude. V8, is it for a SIX!
62champ
07-03-2018, 07:48 AM
V8 pump with the glass bowl - uses the same rebuild kit as 57 and 58 Golden Hawks.
Need to probably get the correct tools and get it out. Thanks.
62champ
07-03-2018, 10:22 AM
Roy - no way to get the end of the diaphragm assembly post off the fork in the arm - not enough room in top of housing.
Thanks Matt - that did the trick - was worried the vice grips might make some burs on the pin but it is a lot harder than the rest of the assembly - now for the removal of the broken screws...uhh.
