I have some semi- fluid grease that I want to put in my 1953 Commander steering box but I want to check if there are any tips for getting it in.
I took the fill plug out but it looks like part of the inside of the box is in the way. Also, it appears like a previous owner may have put 90W oil in it because I have
had a leak which I'm now pretty sure is coming from where the shaft comes out of the box. Do I need to take the side plate off to check and clean it out first?
I can't see anything that looks like a drain plug. Thanks in advance for any advice.
