Which car used this shift pattern?
Originally posted by rkapteyn View Post[ATTACH=CONFIG]73455[/ATTACH]
I found this dial with a stash of Packard and Studebaker
parts P N H D L R
Was this for the 56J?
Bill
I do not remember any Packard or 56J having that "H" (High?) in there though.
Maybe some kind of Hydramatic, or Powerslide AFTER they figured out how to put a "P" Park in there?Last edited by StudeRich; 06-26-2018, 10:21 AM.StudeRich
In the 56J, there were "triangle" indicators either side of Drive, I believe to select first gear or second gear start (only 2 speeds plus torque convertor lockup).Howard - Los Angeles chapter SDC
'58 Packard Hawk. A partially restored car that was not completely assembled.
Just a guess but it seems like it was from a 50's GM hydromatic possibly.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
All the Hydramatics I have seen had NO Park position, Reverse was used once it stopped spinning, so unless it's a Jetaway or something else much newer than the '55 Olds I had, I have no idea.StudeRich
Originally posted by StudeRich View PostI do not remember any Packard or 56J having that "H" (High?) in there though.
The shift dials on 1955/56 Packards were located in the dash. Studebaker, 1950/54 Packard & 1957/58 Packabakers shift dials located on the column.
Jet-Away Hydra-Matic introduced in 1956, standard equipment on Cadillac & Olds 98, optional in Olds 88 and Pontiac.
All '57's and thru 1963 used Jet Away, that have a P in the shift dial.
Prior to Jet Away, you placed the Hydra-Matic shift lever in reverse (once the engine was off) to keep the vehicles from rolling.
I'd be willing to be that 90% of the people that own these cars today are unaware of this.
btw: In 1953, after the Hydra-Matic factory burned down, Pontiac's came with Power-Glide and Olds & Cadillac came with Dynaflow.
My dad once told me, if you see an '53 Olds or Cadillac w/a P in the shift dial, it's Dynaflow.Last edited by WinM1895; 06-28-2018, 11:50 AM.
Originally posted by 6hk71400 View PostJust a thought: Hudson with a Packard V8 and Ultramatic?
Absolutely!
Early 1956 Nash and Hudson came with the Packard 352 and the choice of these three trannies.
Packard prez James J. Nance made a deal with AMC, Packard would buy certain parts from them, if AMC would buy certain parts from Studebaker-Packard.
AMC got the short end of the stick, the only parts Packard bought was the in-dash A/C that Nash had developed. This A/C was only used in Packard/Clipper.
When the new AMC V8 was introduced, the deal was cancelled.
1955/56 Nash and Hudson also came with 6 cylinder engines. Nash was OHV, Hudson was a flathead.Last edited by WinM1895; 06-28-2018, 12:14 PM.
