Does anyone know if there was ever a manual ‘56 Golden Hawk with the stick on the floor that came off the line that way? The vin is 6800T68 on the Golden Hawk I’m looking at.
1956 Golden Hawk, manual with stick on the floor.
No there was not.
I am currently working on one manual trans ‘56 GH for a friend, and restoring another ‘56 GH for myself, also a manual trans car.
I say this because I am becoming pretty familiar with the set-up, and I might have a few hard to find stock manual trans parts that may help you if you buy that car and want to return it to stock. Good luck with your purchase!1950 Commander Land Cruiser
1951 Champion Business Coupe
1951 Commander Starlight
1952 Champion 2Dr. Sedan
1953 Champion Starlight
1953 Commander Starliner
1953 2R5
1956 Golden Hawk Jet Streak
1957 Silver Hawk
1957 3E5 Pick-Up
1959 Silver Hawk
1961 Hawk
1962 Cruiser 4 speed
1963 Daytona Convertible
1964 Daytona R2 4 speed
1965 Cruiser
1970 Avanti
Originally posted by JohnnyG View PostDoes anyone know if there was ever a manual ‘56 Golden Hawk with the stick on the floor that came off the line that way? The vin is 6800T68 on the Golden Hawk I’m looking at.
I have worked on a '56 Golden Hawk with three speed and overdrive (column shift). I remember it as being a heavy transmission (changing a pilot bearing).
The car in question may have been converted from the more common automatic transmission or perhaps just the shift mechanism was changed.
I believe that you are incorrect on the Serial Number. Studebaker used an I for a 1. That is probably what you are calling a T (poorly stamped I).
6800168 would be a Vernon (LA) assembled 1956 Golden Hawk about mid-way through the run.Gary L.
Thanks for the replies! I actually got the wrong vin. The right vin is 6031614. It’s a manual on the floor with bucket seats. I’m guessing someone had changed quite a bit on the car from original. I have only seen pics of bench seats in the 56 Golden Hawk’s.
Yes, there have been many floor shift conversions. Back when the '56J was just a used car, JC Whitney sold conversion kits for $19.95.
No, there were none built as floor-shifted, but several automatics have been converted to manual, 3-speed, 4-speed, 5-speed and 6-speed.
Maybe, some more detail would confirm exactly what you've got.
jack vinesPackardV8
Originally posted by JohnnyG View PostThanks for the replies! I actually got the wrong vin. The right vin is 6031614. It’s a manual on the floor with bucket seats. I’m guessing someone had changed quite a bit on the car from original. I have only seen pics of bench seats in the 56 Golden Hawk’s.Gary L.
If we assume the engine is original, the serial number will be K????. If ultramatric, E???? If any thing else, maybe from a Packard.78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
55 Speedster 7160047
55 Speedster 7165279
If it was Ultramatic, the engine number should start with an "S".Howard - Los Angeles chapter SDC
'58 Packard Hawk. A partially restored car that was not completely assembled.
