View Full Version : Fuel System: Looking for a 289 GT Hawk air cleaner
avanti-hawk
06-24-2018, 12:42 PM
I need a proper fitting air cleaner for my 289 4 barrel 1963 Hawk. Aftermarket is fine with me.
Any recommendations?
06-24-2018, 02:29 PM
Most New Aftermarket Air Cleaners without Silencers and without Dirt, Water and Oil protective covers are available everywhere, Auto Parts Stores and on-line.
However they are all made to except the New Edelbrock Carbs. with 5 1/8 Inch openings, so to fit your Carter WCFB or AFB that is 4 1/8", you also need the Adapter.
Some vendors at: http://studebakervendors.com MAY still have 1959 to 1964 4 Brl. Stock United Specialties, OEM Studebaker, much BETTER Air Cleaners $$$, OR you can easily find 2 Brl. ones and open up the Carb. hole. ;)
rkapteyn
06-24-2018, 03:39 PM
You can use your original air cleaner and buy a bottom plate to fit the Edelbrock.
avanti-hawk
06-24-2018, 08:13 PM
I do not have the original. It's an aftermarket that is too big at the base for the stock 4 1/8' carb throat
63t-cab
06-24-2018, 08:18 PM
Edward, I sent You a PM.
bensherb
06-24-2018, 09:54 PM
Here's what you need $6.46 : https://www.summitracing.com/parts/mrg-2082
avanti-hawk
06-26-2018, 07:02 PM
I didn't receive the PM
avanti-hawk
06-26-2018, 07:11 PM
Ok. Thanks That might do the trick. But just checked the throttle linkage and it looks like too much play in the baseplate butterfly shaft. So I dont know if the carb is just worn out or can be rebuilt. Probably need a new carb. I just wanted it running good to sell. The person who I bought it from had some crappy work done and I don't wish to pass that garbage stuff on to the next owner. Maybe he bought it that way, but the asshat who did the appraisal missed a large amount of obvious mistakes or just lied about the condition:mad:
