View Full Version : Front Axle: 56J Packard spring replacement
Santosh
06-13-2018, 02:15 AM
I have to replace parts of the front axle. Any idea for replacement the springs? I think stronger ones would be better?
Jeffry Cassel
06-13-2018, 06:35 AM
Have a pair of front coil springs for 56J. You can have them for shipping. Where are you?? 20 years ago built 66 Mustang for daughter's graduation car. Purchased brand new repro coils for it. When insalled the front end was several inches too high and had to remove them and cut one coplete coil out of each one and re-installed. Perfect. Had 56J years ago and never liked the way it handled: like a heavily loaded forklift. But it would sure go! I' pretty sure these are good standard rate springs. Might have a set of Olds Vista Cruiser rear coils but don't know the rate on these. I'm sure you could find out Googlr or ask Jim Pepper
JoeHall
06-13-2018, 10:57 AM
Call Coil Spring Specialties (CSS), and have them make you a pair of Stude part #526125. They are the factory HD springs for 56J. Most 56Js came with 526124, which is way too wimpy for 56J. CSS will make them identical to the originals.
Santosh
06-13-2018, 02:06 PM
Thanks for your response, CSS offers to make springs more stiffer, I think 10 percent, thats what my 56J will need.
JoeHall
06-13-2018, 04:15 PM
I would go with 526125, and not any stiffer. The factory got it right with the 125s, but failed miserably with the 124s. I believe every 56J shoulda came with the 125s, and cannot fathom why most 56Js came with the 124s. For the 56J, you will not find a better riding and performing spring than the 125s. If you make the springs too stiff, it will put more stress on the front section of the frame, which is already marginal on the 56J.
While you are at it, a good upgrade for your 56J is to install a 1963 and later Stude V8 anti-sway bar & support stanchions. That will make it handle a lot better in sweepers and sharp turns. You can add to that, and make it even better with a Dave T rear anti-sway bar. But the front bar will make the most difference.
64V-K7
06-14-2018, 05:22 AM
I thought the gauge steel used on the 56J's was heavier than the others
JoeHall
06-14-2018, 08:26 AM
Too lazy to look it up, but pretty sure all V8, 1956 frames were same thickness. The GTs, and later all V8 frames were thicker. Trust me, the 56Js frame is a weak point in the car. Cracks, and ripped out upper, inner 'A' arm pivot mount bolts are far more common in 56J than all other V8 Hawks combined. Further, they need more frequent care and attention than the other V8 Hawks or cars, i.e. 'A' arm bushings, king pin wear, loosened bolts, etc..
