View Full Version : Looking for a Brake pedal part for friend, 53-54 CK
lelshaddai
06-07-2018, 10:42 AM
I am trying to help out a friend that has a 54 Coupe. He needs the large pedal shaft bolt 1108-3, bushing, 1108-2 and spring 1108-5. If you have something like this please let me know.
Jim
https://s19.postimg.cc/5rwt8djar/2018-06-06_22.45.37.jpg (https://postimg.cc/image/9oa54d4a7/)
RadioRoy
06-07-2018, 11:05 AM
Studebakers West should have these, as well as Studebaker International.
bensherb
06-07-2018, 06:31 PM
You should be able to get the bolt and nut at any hardware store. I removed my clutch (went to auto trans) and replaced the pin with a standard bolt, no sweat. I think it was 5/8" but measure to be sure.
dpson
06-07-2018, 07:31 PM
Jim,
The numbers you listed above (1108-2,etc.) are illustration numbers the actual parts numbers are 517152 for the bushing, 535189 for the spring and 2-0688 for the bolt. The bolt is listed as 3/8" - 24 (threads per inch) x 4-7/8" and as others have noted can probably be found at the hardware store or on-line.
Jeffry Cassel
06-08-2018, 08:28 AM
Hardware bolt should do. If you are OCD enough to need the exact bolt you should be able to find one at SI, Studepakerpartsonline, or Studebaker west. I guessed the brakes on these cars were so God-awful that they made the double pedal so that you could push with both feet!
