I'm in a quandary. I have recently obtained an older restoration '46 M5 pickup and have worked through many issues getting it ready for the road again. Those issues being rebuilding hydraulic brakes, cleaning/sealing the fuel tank, replacing fuel sender unit, getting an ignition key made, and now for sorting out the electrical system.
The truck was restored in 2008 and has been stored in a shipping container for the last decade. It had a dead 12 volt battery hooked up with negative earth. It has a 6 volt generator, original 3-lead regulator mounted on the firewall. It has a generic starter solenoid mounted on the firewall and what appears to be a newer "rebuilt" starter motor.
So therein i am at first very confused concerning the wiring circuit, whether 12 or 6 volt. Now i hooked up a fully charged 12 volt battery and the truck started right up and runs fine, however the regulator was rhythmically clicking away and the ammeter showed a discharge. While running, i pulled the battery cable off and the truck stopped running (i thought they would continue to run off the generator)?
I could not tell externally whether the generator was 12 volt of 6 volt, so i pulled it off and bench tested to find it putting out 7 volts. So i went and bought/installed a new fully charged 6 volt battery, hooked it up with positive ground and tried to start the trunk......NOTHING, just ammeter discharge attempting turning the key. Then i switched polarity to negative ground, still nothing. So i left in place and jumped with an external 12 volt battery. Truck started right up. I removed jumpers and the truck continued to run off the 6 volt battery. Revving up the engine the ammeter appeared to "very slightly" show a charge (as opposed to an obvious discharge) however when i turned on headlights, the revving did not offset the discharge with lights on.
So my concern is thinking i would like to keep original and stick with the 6 volt setup, however i think i may have a "mixture" of 6 and 12 volt components and don't know what to do. The starter relay and starter motor only seemed to respond to the 12 volt battery, but i know for a fact that the generator is only putting out 7 volts.
My question then, should i seek out and switch/install a 12 volt generator and equip the truck with a 12 volt battery? Or what is keeping my starter solenoid and starter motor from working with the 6 volt battery hookup???
PLEASE HELP!!!!
