View Full Version : I Need 2 Front Arm Rests and the Rubber for the Steering Column to Cowl Seal 1950 L/C
TWChamp
05-01-2018, 10:51 AM
I need the rubber steering column seal where the steering enters the cowl on the inside.
Part number 291321, and new or good used will be fine. I can pick it up at the South Bend Swap this week, if you have one.
I also need the 2 front door arm rests, as mine were recovered in the wrong material. 1950 Land Cruiser
55 56 PREZ 4D
05-01-2018, 04:00 PM
If you have the arm rests, could you recover them in the correct material ?
TWChamp
05-01-2018, 06:46 PM
I was thinking about trying that if I can't find good ones. If I can find some bad door panels with enough of the grey alligator material, and the correct cloth, I could try sewing them together for a cover. Hopefully there will be something at SB this week.
BTW, my steering wheel also needs repair due to 2 large separations in the plastic. Last year there was a mint steering wheel at the SB swap that I was thinking of buying, just in case I need it in the future. When I went back to buy it, it was sold of course.
