View Full Version : New member needing information
Kenneth
04-06-2018, 08:30 AM
I have acquired a "50 something" 2R5-12 Serial # R5 94368 The engine is a v-8. The rear lug nuts resemble a 3/4 ton. I am not sure if these items were original equipment. What is the approximate value of this truck?7157071571Needing input from Studebaker enthusiast.
Skip Lackie
04-06-2018, 09:08 AM
Your truck is a 1952 model 2R5 that originally came with a 170 cu in Champion 6 engine. It was Studebaker's biggest seller. The V8 was not available in half-ton pickups until 1955. Yes, that rear axle appears to be from a heavier truck and would not have been available in the model 2R5. The correct Dana 44 axles are not that hard to find. Value depends on the amount of rust and how good/bad the mechanicals are.
Lamar
04-06-2018, 11:43 AM
Where in Ms? Lamar
kurtruk
04-07-2018, 12:19 AM
The value of it is exactly what you paid for it. :)
Looks like a decent truck depending on what you want it for.
BTW: That is a Stude engine in it now.
Guess it doesn't run, eh?
Skip Lackie
04-07-2018, 08:34 AM
To go back to the original question, 2R pickups with non-running engines and lots of rust often go for about $500 for the usable parts, like glass, transmission, rear axle, brake drums, etc. Fully and authentically restored Stude pickups, especially later-models with V8s, have gone for as much as 25 - 30K -- but it's easy to spend more than that on restoration if you don't do most of the work yourself. The big weakness is rust -- in the floors, door bottoms, front fenders, etc. All mechanical parts to restore these trucks are available, but can cost a lot if everything needs to be done. Would need to have more info before anyone can answer the value question.
Kenneth
04-07-2018, 10:18 AM
Meridian. The truck is very sound. I acquired the truck thru an inheritance.
Kenneth
04-07-2018, 10:20 AM
The engine will turn over, I have an issue with the carb. right now. Thanks for the information. The truck is for sale as is. The interior is excellent.
Kenneth
04-07-2018, 10:24 AM
The engine does crank but will not start, I am having issues with the carb. Interior is in great shape. Thanks for the info.
Lamar
04-08-2018, 02:17 AM
Pm me a price. Lamar
jackb
04-10-2018, 09:45 AM
An engine that won't start could mean almost anything. Get it to run and interest will climb...
