View Full Version : Voltagr regulator markings
RSykes
04-02-2018, 05:07 PM
My '64 Studebaker Champ P/U was manufactured with DEV. 5605, which means it was equipped with an alternator. It has a four tang external regulator (Delco-Remy). The tangs are marked F, 1, 2, 3, 4. What do those correspond to--like, which one is the armature, for example?
Thanks,
RES
Ron Strasser
04-02-2018, 05:34 PM
RSkles;
Sounds like the alternator and regulator is special. Need the manufactures model number of each item.
Ron
04-02-2018, 07:32 PM
Yep, Special Order.
The info should be in the Truck Shop Manual for the optional H.D. Alternators and Generators.
Dwain G.
04-03-2018, 01:04 AM
Seems like we did this once before. I don't remember if a wiring diagram was found. If you Google a Chevrolet alternator diagram from the same year it will show where all the wires go but they probably won't be the same color as Studebaker.
