View Full Version : I am so pleased !!
Warren Webb
03-26-2018, 01:58 PM
This past weekend a critical test has been performed on my 62 Champ with the 5 speed overdrive. Before it would run ok around town but overheat on the freeway after less than 5 miles. Not good at all. So, thanks to the forum I undertook cleaning out the block, removing all the core plugs (freeze plugs to many) & making the engine as spotless as one can on that rusted iron. I had the truck shipped out to the new home here in Arizona & replaced the fuel pump. (thanks Rich aka StudeRich) and was ready for the ultimate test, pulling my 500 gallon water trailer. Down to town for the water wasn't too much of a worry but coming back with a load, uphill was. It performed flawlessly! Even pulled better than I had expected !
One other thing I did to the truck was making a bracket to add support to the unused firewall bracket to support the cab. The doors were getting real hard to close due to their misalignment & the "A" pillar sagging. Floor had some surface rust but was pretty solid so additional support was required. I took some 1/2 flat stock, bent a 90 degree angle to it & drilled with it in position through the bracket & in through the frame. 2 5/16ths by 2 1/2" locking bolts was the perfect length. Nowe my doors close once again like it just rolled off the line.
03-26-2018, 03:02 PM
WOW! A Major Score times THREE! Glad you got er done Warren! :!:
jackb
03-26-2018, 03:44 PM
not for any other reason but for questioning: is it advisable to mount the T-cabs to their frames as done above like the Larks ??
jclary
03-26-2018, 04:36 PM
I bet you feel as relieved as I do about getting this year's taxes done & filed before the 1st of April!!!:cheers:
My wife stated that since I retired, I should be very grateful I no longer have to submit all those justifications, and spend days pouring over receipts, and dealing with CPA'S like I used to. My response was that the emotion of, disgust and stress, over the process, is still the same:mad:, even if it is much simpler.;) But...when completed, the joy is just as good too!:!:
As for your job, if you are anything like I am, it is the fear of the unknown, what could go wrong, that makes you hesitate to tackle the task. Only, to find that diving into the work, and getting 'er done, was never as bad as you had imagined.:)
showbizkid
03-26-2018, 04:38 PM
Nice one Warren!
Does that firewall bracket trick work on Lark sedans, I wonder?
Studebakercenteroforegon
03-26-2018, 04:42 PM
Nice one Warren!
That firewall bracket is FOR Lark body styles, so your Lark left South Bend with the body and frame attached there as intended.
63t-cab
03-26-2018, 04:43 PM
That's a question I also wonder about Jack. My Champ is gonna get some re work for the same Cowl shake/sag,but thought I'd just go considerably heavier with Floor Panel gauge and reinforce needed areas like there is no Tomorrow ! I don't know if mounting the front would cause stress on the Cab when the Frame Rails move and twist ?
showbizkid
03-26-2018, 06:27 PM
Ha! Yeah, silly question now that I re-read it :rolleyes:
DEEPNHOCK
03-26-2018, 06:29 PM
Was that a T5 conversion you put in your Champ?
03-27-2018, 03:01 AM
I think that Champ has the Factory New Process H.D. 5, O.D.
Warren Webb
03-28-2018, 02:49 PM
Rich is correct. It has the factory equipped New Process trans. I now need to register both 62 Champs for the "Fun Run" held in Seligman every May. Gives a purpose for the front license bracket now sitting empty since they both lost their California plates.
