View Full Version : Rear Brake Drums
57studechampion
03-23-2018, 09:15 PM
I am working on the rear axle of my 56 Champion and discovered a problem with my rear drums. See picture71220
Does anyone have or know where I can get a new, newer or better set than I have? I feel these might be a little unsafe to drive. I prefer with hubs.
Thanks
TWChamp
03-24-2018, 09:37 AM
Can that be placed on a block of steel and pressed or hammered flat?
I'm not familure with the 56, so are they slip on, or are they swaged?
57studechampion
03-24-2018, 12:01 PM
I could possibly do that but the holes are also oblong now.71260
jackb
03-24-2018, 01:00 PM
jeeesh... I just dumped a bunch of these at the dump 2 weeks ago. Kept the front V8 drums/hubs. Next thing you know someone will want an AS carburetor and intake/exhaust manifolds.....Swap Page
57studechampion
03-24-2018, 01:35 PM
I have already checked the swap page. No Luck
03-24-2018, 02:06 PM
Once the Swagged Studs have been pressed, or ripped out incorrectly, they are pretty much Toast.
Since Studebaker Drums Center on the Stud Holes NOT the Center Hole to properly "Center" they need to be Swagged onto the Hub like they once were.
Depending on their out of round and oversize, amount they may be junk anyway, time for New ones.
63t-cab
03-24-2018, 02:26 PM
Don, if You run out of options. I have a n.o.s. 9" Drum "Drum only with out Hub" I'd sell if interested.
jackb
03-24-2018, 07:00 PM
I've got to believe there are 100's of these out in Studedom in the barn or like mine, in my cellar.
TWChamp
03-24-2018, 07:05 PM
If nothing else, you can always have new holes drilled half way between these. but that would take some precise marking.
TX Rebel
03-24-2018, 11:28 PM
I have a large drum inventory here @ the Texas Studebaker Ranch
https://www.studebakersite.com
